Ir para o conteúdo principal
Canon Powershot SX30 IS LCD Panel Front Cover Replacement
O que você precisa
  1. Canon Powershot SX30 IS LCD Panel Front Cover Replacement, LCD Panel Rear Cover: passo 1, imagem 1 %32
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 2, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 2, imagem 2 %32
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 3, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 3, imagem 2 %32 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 3, imagem 3 %32
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 4, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 4, imagem 2 %32
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 5, imagem 1 %32
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
  6. Canon Powershot SX30 IS LCD Panel Front Cover Replacement, LCD Panel Front Cover: passo 6, imagem 1 %32
    • Unscrew the 2mm screw on the outer edge of the panel
  7. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 7, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: passo 7, imagem 2 %32
    • Unscrew the 3mm screw on the inner edge of the panel. This is easily done by rotating the screen to be perpendicular to the body of the camera, but be careful not to damage the wires or the circuit board.
    • The panel will fall right off
Conclusão
Ellis DeVoe
Membro desde: 04/14/15
580 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-12, Maness Spring 2015 Membro de Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 585
