Ir para o conteúdo principal
Canon Powershot SX30 IS Battery/SD Card Door Replacement
O que você precisa
  1. Canon Powershot SX30 IS Battery/SD Card Door Replacement, Battery/SD Card Door: passo 1, imagem 1 %32
    • Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
  2. Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 2, imagem 1 %32 Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 2, imagem 2 %32
    • Unscrew the two 2mm screws from the inside of the case
  3. Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 3, imagem 1 %32 Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 3, imagem 2 %32
    • Remove the plastic backing and the metal front plate from the spring controlled hinge
    • To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
Conclusão
That's It! Good Job!
Ellis DeVoe
Membro desde: 04/14/15
580 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-12, Maness Spring 2015 Membro de Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
Membros da 4
Autoria de 5 guias
Um comentário
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
jusanotherhuman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 674
