Ir para o conteúdo principal
Canon Powershot SX30 IS Back Camera Housing Replacement
O que você precisa
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: passo 1, imagem 1 %32 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: passo 1, imagem 2 %32
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 2, imagem 1 %32 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 2, imagem 2 %32 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 2, imagem 3 %32
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 3, imagem 1 %32 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 3, imagem 2 %32
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 4, imagem 1 %32
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 5, imagem 1 %32
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 6, imagem 1 %32 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 6, imagem 2 %32
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 7, imagem 1 %32
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 8, imagem 1 %32
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 9, imagem 1 %32
    • Close the back cover, and re-insert appropriate screws.
Conclusão
Ellis DeVoe
Membro desde: 04/14/15
580 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-12, Maness Spring 2015 Membro de Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 1,380
