Ir para o conteúdo principal
Canon Powershot SX10 IS LCD Screen Replacement
O que você precisa
  1. Canon Powershot SX10 IS LCD Screen Replacement, Lithium Ion Battery: passo 1, imagem 1 %32
    • Open the door. Release the catch by sliding it towards the side of the camera.
    • Then slide the door towards the front of the camera.
  2. Canon Powershot SX10 IS LCD Screen Replacement: passo 2, imagem 1 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 2, imagem 2 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 2, imagem 3 %32
    • Remove AA batteries.
    • Using a fingernail or iFixit opening tools to pry up the battery cradle.
    • Remove CR1220 battery from the cradle.
  3. Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: passo 3, imagem 1 %32 Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: passo 3, imagem 2 %32
    • Remove all four screws on the corners of the screen cover.
    • Gently pry open the cover with a fingernail or iFixit opening tool.
  4. Canon Powershot SX10 IS LCD Screen Replacement: passo 4, imagem 1 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 4, imagem 2 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 4, imagem 3 %32
    • Remove two screws holding on the cover plate on the pivot.
    • Remove the cover plate using an iFixit opening tool.
    • You may need to loosen the bottom first, then pry on the top of the cover plate.
    • Remove the two screws on top of the swivel arm. These two screws will be separated by the pivot point.
  5. Canon Powershot SX10 IS LCD Screen Replacement: passo 5, imagem 1 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 5, imagem 2 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 5, imagem 3 %32
    • Remove grounding wire, then continue to remove the screws holding the screen and front cover plate on.
    • The screen and plate will drop after removing the last screw.
  6. Canon Powershot SX10 IS LCD Screen Replacement: passo 6, imagem 1 %32 Canon Powershot SX10 IS LCD Screen Replacement: passo 6, imagem 2 %32
    • Unlatch the ribbon strip and power wires from the circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 32
Duração total: 1,279
