Ir para o conteúdo principal
Canon Powershot SD880 LCD Display Replacement
O que você precisa
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: passo 1, imagem 1 %32 Canon Powershot SD880 LCD Display Replacement, Back Cover: passo 1, imagem 2 %32 Canon Powershot SD880 LCD Display Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: passo 2, imagem 1 %32 Canon Powershot SD880 LCD Display Replacement, LCD Display: passo 2, imagem 2 %32 Canon Powershot SD880 LCD Display Replacement, LCD Display: passo 2, imagem 3 %32
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Conclusão
Ben Tupas
Membro desde: 01/13/11
317 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 13-3, Forte Winter 2011 Membro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
Membros da 5
Autoria de 8 guias
Um comentário
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 2,316
