Ir para o conteúdo principal
Canon Powershot SD880 Front Cover Replacement
O que você precisa
  1. Canon Powershot SD880 Front Cover Replacement, Back Cover: passo 1, imagem 1 %32 Canon Powershot SD880 Front Cover Replacement, Back Cover: passo 1, imagem 2 %32 Canon Powershot SD880 Front Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Front Cover Replacement, Front Cover: passo 2, imagem 1 %32 Canon Powershot SD880 Front Cover Replacement, Front Cover: passo 2, imagem 2 %32 Canon Powershot SD880 Front Cover Replacement, Front Cover: passo 2, imagem 3 %32
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
Conclusão
Robert Manno
Membro desde: 01/05/11
432 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-3, Forte Winter 2011 Membro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 2,816
