Ir para o conteúdo principal
Canon Powershot SD550 Zoom Lens Assembly Replacement
O que você precisa
  1. Canon Powershot SD550 Zoom Lens Assembly Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 2, imagem 1 %32
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 3, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 3, imagem 2 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 3, imagem 3 %32
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 4, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 4, imagem 2 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 4, imagem 3 %32
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 5, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 5, imagem 2 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 5, imagem 3 %32
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 6, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 6, imagem 2 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 6, imagem 3 %32
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 Zoom Lens Assembly Replacement, LCD Screen: passo 7, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement, LCD Screen: passo 7, imagem 2 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement, LCD Screen: passo 7, imagem 3 %32
    • Peel the navigation buttons from the button panel and set them aside.
    • To free the LCD display, remove the 2.9 mm screw in the top left corner.
    • Rotate the screen clockwise until it lifts away from the camera.
    • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
  8. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 8, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 8, imagem 2 %32
    • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
    • After disconnecting both cables, pull the screen away from the camera to remove it.
  9. Canon Powershot SD550 Zoom Lens Assembly Replacement, Image Sensor: passo 9, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement, Image Sensor: passo 9, imagem 2 %32
    • Now the photo sensor is exposed. In order to remove the ribbon cable from its port, first flip up the blue locking mechanism.
    • After the cable is unlocked, it easily pulls free.
  10. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 10, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 10, imagem 2 %32
    • In order to remove the photo sensor, you will have to cut through glue and remove screws.
    • Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
    • WARNING: Knives are sharp. Treat them with respect.
    • Now remove the three .15 inch screws holding the photo sensor to the camera frame.
  11. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 11, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 11, imagem 2 %32
    • Now you can carefully lift up the image sensor and remove it from the camera.
    • Be careful not to lose the three small springs or the rubber grommet that lie beneath the sensor.
  12. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 12, imagem 1 %32
    • You have now successfully removed the image sensor.
  13. Canon Powershot SD550 Zoom Lens Assembly Replacement, Flash Bulb Assembly: passo 13, imagem 1 %32
    • Once the image sensor is removed, turn the camera over and find the screw in the bottom right corner.
    • Remove this .01 inch screw to free the ribbon cables.
  14. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 14, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 14, imagem 2 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 14, imagem 3 %32
    • One by one, detach the three ribbon cables from their ports.
  15. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 15, imagem 1 %32
    • Pay special attention when removing this connector. It does not pull out like the rest of them. Instead, you must use a spudger to lift the connector vertically out of its slot.
  16. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 16, imagem 1 %32
    • Flip the camera over again so that the rear is showing and remove the two .065 inch screws holding the flash unit in place. They should be on the left side.
  17. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 17, imagem 1 %32
    • Now you should be able to remove the flash unit from the camera.
    • When removing the flash, be careful when handling the capacitor. It may contain a powerful charge. Discharge may result in damage and personal injury.
  18. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 18, imagem 1 %32
    • You have now successfully removed the flash unit.
  19. Canon Powershot SD550 Zoom Lens Assembly Replacement, Zoom Lens Assembly: passo 19, imagem 1 %32
    • Next, remove the three .12 inch screws that hold the lens assembly to the camera.
  20. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 20, imagem 1 %32 Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 20, imagem 2 %32
    • Finally, pull the lens assembly away from the camera frame. Make sure that none of the ribbon cables are tangled up.
  21. Canon Powershot SD550 Zoom Lens Assembly Replacement: passo 21, imagem 1 %32
    • You have now successfully removed the Canon PowerShot SD550 Lens Assembly.
Conclusão
Matthew Theiss
Membro desde: 04/14/11
176 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-23, Garner Spring 2011 Membro de Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
Membros da 5
Autoria de 7 guias
Um comentário
hi. please help me to reassemble the lens completly.
thanks.
esmaeil - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 3,804
