Ir para o conteúdo principal
Canon Powershot SD550 Shutter Button Replacement
O que você precisa
  1. Canon Powershot SD550 Shutter Button Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Shutter Button Replacement: passo 2, imagem 1 %32
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Shutter Button Replacement: passo 3, imagem 1 %32 Canon Powershot SD550 Shutter Button Replacement: passo 3, imagem 2 %32 Canon Powershot SD550 Shutter Button Replacement: passo 3, imagem 3 %32
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Shutter Button Replacement: passo 4, imagem 1 %32 Canon Powershot SD550 Shutter Button Replacement: passo 4, imagem 2 %32 Canon Powershot SD550 Shutter Button Replacement: passo 4, imagem 3 %32
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Shutter Button Replacement: passo 5, imagem 1 %32 Canon Powershot SD550 Shutter Button Replacement: passo 5, imagem 2 %32 Canon Powershot SD550 Shutter Button Replacement: passo 5, imagem 3 %32
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Shutter Button Replacement: passo 6, imagem 1 %32 Canon Powershot SD550 Shutter Button Replacement: passo 6, imagem 2 %32 Canon Powershot SD550 Shutter Button Replacement: passo 6, imagem 3 %32
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 Shutter Button Replacement, Shutter Button: passo 7, imagem 1 %32 Canon Powershot SD550 Shutter Button Replacement, Shutter Button: passo 7, imagem 2 %32
    • Next, unscrew the .115 inch screw fastening the shutter button to the camera.
    • Now lift the button away from the camera, exposing the button board.
    • You have successfully removed the shutter button.
Conclusão
Ken Michael
Membro desde: 04/17/11
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-23, Garner Spring 2011 Membro de Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,510
