Ir para o conteúdo principal
Canon Powershot SD550 Image Sensor Replacement
O que você precisa
  1. Canon Powershot SD550 Image Sensor Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Image Sensor Replacement: passo 2, imagem 1 %32
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Image Sensor Replacement: passo 3, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 3, imagem 2 %32 Canon Powershot SD550 Image Sensor Replacement: passo 3, imagem 3 %32
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Image Sensor Replacement: passo 4, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 4, imagem 2 %32 Canon Powershot SD550 Image Sensor Replacement: passo 4, imagem 3 %32
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Image Sensor Replacement: passo 5, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 5, imagem 2 %32 Canon Powershot SD550 Image Sensor Replacement: passo 5, imagem 3 %32
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Image Sensor Replacement: passo 6, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 6, imagem 2 %32 Canon Powershot SD550 Image Sensor Replacement: passo 6, imagem 3 %32
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 Image Sensor Replacement, LCD Screen: passo 7, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement, LCD Screen: passo 7, imagem 2 %32 Canon Powershot SD550 Image Sensor Replacement, LCD Screen: passo 7, imagem 3 %32
    • Peel the navigation buttons from the button panel and set them aside.
    • To free the LCD display, remove the 2.9 mm screw in the top left corner.
    • Rotate the screen clockwise until it lifts away from the camera.
    • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
  8. Canon Powershot SD550 Image Sensor Replacement: passo 8, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 8, imagem 2 %32
    • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
    • After disconnecting both cables, pull the screen away from the camera to remove it.
  9. Canon Powershot SD550 Image Sensor Replacement, Image Sensor: passo 9, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement, Image Sensor: passo 9, imagem 2 %32
    • Now the photo sensor is exposed. In order to remove the ribbon cable from its port, first flip up the blue locking mechanism.
    • After the cable is unlocked, it easily pulls free.
  10. Canon Powershot SD550 Image Sensor Replacement: passo 10, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 10, imagem 2 %32
    • In order to remove the photo sensor, you will have to cut through glue and remove screws.
    • Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
    • WARNING: Knives are sharp. Treat them with respect.
    • Now remove the three .15 inch screws holding the photo sensor to the camera frame.
  11. Canon Powershot SD550 Image Sensor Replacement: passo 11, imagem 1 %32 Canon Powershot SD550 Image Sensor Replacement: passo 11, imagem 2 %32
    • Now you can carefully lift up the image sensor and remove it from the camera.
    • Be careful not to lose the three small springs or the rubber grommet that lie beneath the sensor.
  12. Canon Powershot SD550 Image Sensor Replacement: passo 12, imagem 1 %32
    • You have now successfully removed the image sensor.
Conclusão
3 outras pessoas executaram este guia.
Matthew Theiss
Membro desde: 04/14/11
176 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-23, Garner Spring 2011 Membro de Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 2,784
