Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Pull the orange lever and the battery will spring out slightly.
Grasp the battery and fully pull it out of its slot.
Locate the sliding button labeled "CF OPEN."
Place your finger on the button and slide it in the direction of the arrow.
The side panel will flip open revealing the compact flash memory card.
Locate the gray button at the bottom of the open slot.
Place your finger on the button and push it down.
The memory card will pop out slightly.
