Ir para o conteúdo principal
Introdução
The screen is a crucial part of the camera: it displays images for consumers to view their pictures instantly. Damage to the screen may require replacement.
Peças
Nenhum componente especificado.
  1. Slide the grey latch to open the battery compartment. Slide the grey latch to open the battery compartment.
    • Slide the grey latch to open the battery compartment.
  2. Push and slide the orange retaining clip to the right to remove the battery. Push and slide the orange retaining clip to the right to remove the battery.
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Remove battery from the camera.
    • Remove battery from the camera.
  4. Remove the lanyard.
    • Remove the lanyard.
  5. Position the camera so that the bottom is facing up.
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Remove the 3.8mm screw from the back face of the camera.
    • Remove the 3.8mm screw from the back face of the camera.
  7. Remove the two 2.3mm screws from the right face of the camera.
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Pull the back face panel away from the front end of the body. This may take some wiggling and force.
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Remove the CF card door from the left side of the camera body. Remove the CF card door from the left side of the camera body.
    • Remove the CF card door from the left side of the camera body.
  11. Slide the rubber digital a/v cap out of place on the front plate. Slide the rubber digital a/v cap out of place on the front plate.
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Remove the front face by sliding it off.
    • Remove the front face by sliding it off.
  13. Remove the rubber seal that covers the right side of the viewfinder.
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Remove the two 3.9mm screws that hold the laminated copper sheet.
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Remove the wire connections that connect along the bottom of the motherboard. Remove the wire connections that connect along the bottom of the motherboard.
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Remove the single 3.8mm screw that is on the motherboard.
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Remove the motherboard from the main frame of the camera body.
    • Remove the motherboard from the main frame of the camera body.
  18. After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
    • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
  19. Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
    • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
  20. Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
    • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
    • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
  21. Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
    • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
  22. Unsolder the four points at the top of the screen with a soldering iron
    • Unsolder the four points at the top of the screen with a soldering iron
Conclusão
Uma outra pessoa concluiu este guia.
Anh
Membro desde: 13/04/2011
148 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-70, Walters Spring 2011 Membro de Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Membros
4 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,420
