Introdução
In this guide, the process of partially breaking down the Canon Powershot S110 and replacing the option dial will be explained in detail.
O que você precisa
Remove the battery by sliding open the battery cover on the bottom of the camera.
Remove the six screws by using a small Phillips head screwdriver.
Remove the two screws on the side of the camera on either side of the HDMI input panel.
Remove the two screws on the opposite side of the camera.
Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
2 outras pessoas concluíram este guia.
