Ir para o conteúdo principal
Canon Powershot S110 Option Dial Replacement
O que você precisa
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: passo 1, imagem 1 %32 Canon Powershot S110 Option Dial Replacement, Option Dial: passo 1, imagem 2 %32
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: passo 2, imagem 1 %32 Canon Powershot S110 Option Dial Replacement: passo 2, imagem 2 %32 Canon Powershot S110 Option Dial Replacement: passo 2, imagem 3 %32
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: passo 3, imagem 1 %32
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: passo 4, imagem 1 %32 Canon Powershot S110 Option Dial Replacement: passo 4, imagem 2 %32
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: passo 5, imagem 1 %32
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: passo 6, imagem 1 %32
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: passo 7, imagem 1 %32 Canon Powershot S110 Option Dial Replacement: passo 7, imagem 2 %32
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
Conclusão
akac92
Membro desde: 07/14/15
298 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team 1-2, Liner SU 2015 Membro de UW Tacoma, Team 1-2, Liner SU 2015
UWT-LINER-SU15S1G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,099
