Ir para o conteúdo principal
Canon Powershot Pro1 Lens Replacement
O que você precisa
  1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: passo 1, imagem 1 %32 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: passo 1, imagem 2 %32
    • Have the lens of the camera facing upwards.
    • Find the red plastic ring.
    • Look for two small opening above the red plastic ring.
    • Reference to the left of the picture and you will see the orange square.
  2. Canon Powershot Pro1 Lens Replacement: passo 2, imagem 1 %32 Canon Powershot Pro1 Lens Replacement: passo 2, imagem 2 %32 Canon Powershot Pro1 Lens Replacement: passo 2, imagem 3 %32
    • Remove the plastic ring that has a red strip.
    • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
  3. Canon Powershot Pro1 Lens Replacement: passo 3, imagem 1 %32 Canon Powershot Pro1 Lens Replacement: passo 3, imagem 2 %32 Canon Powershot Pro1 Lens Replacement: passo 3, imagem 3 %32
    • Place the camera on its back with the lens facing upwards as shown in the image
    • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
    • Remove the screw by turning the Philip driver counterclockwise.
    • By removing the screw, you will be able to remove the cover lens.
  4. Canon Powershot Pro1 Lens Replacement: passo 4, imagem 1 %32
    • Use the nylon spudger to remove the ring holding the lens in place.
    • Pull gently until the lens ring snaps off.
  5. Canon Powershot Pro1 Lens Replacement: passo 5, imagem 1 %32
    • Refer to the left-hand pictere to see what the len's ring looks like.
  6. Canon Powershot Pro1 Lens Replacement: passo 6, imagem 1 %32 Canon Powershot Pro1 Lens Replacement: passo 6, imagem 2 %32 Canon Powershot Pro1 Lens Replacement: passo 6, imagem 3 %32
    • Take out the lens once the plastic ring is removed
    • Hold the outer layer of the lens to not create smudges on it.
    • Replace the lens and follow the instruction in reversed order to reassemble the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 63
Duração total: 2,067
