Ir para o conteúdo principal
Canon Powershot Pro1 Flash Replacement
O que você precisa
  1. Canon Powershot Pro1 Flash Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Flash Replacement: passo 2, imagem 1 %32
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Flash Replacement: passo 3, imagem 1 %32
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Flash Replacement: passo 4, imagem 1 %32
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Flash Replacement, Flash: passo 5, imagem 1 %32 Canon Powershot Pro1 Flash Replacement, Flash: passo 5, imagem 2 %32
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
  6. Canon Powershot Pro1 Flash Replacement: passo 6, imagem 1 %32
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
  7. Canon Powershot Pro1 Flash Replacement: passo 7, imagem 1 %32
    • Use the plastic spudger to remove the upper portion of the flash housing.
  8. Canon Powershot Pro1 Flash Replacement: passo 8, imagem 1 %32 Canon Powershot Pro1 Flash Replacement: passo 8, imagem 2 %32 Canon Powershot Pro1 Flash Replacement: passo 8, imagem 3 %32
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
  9. Canon Powershot Pro1 Flash Replacement: passo 9, imagem 1 %32
    • Cut the flash and capacitor cables with a wire cutter.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 705
