Ir para o conteúdo principal
Canon Powershot Pro1 Battery Replacement
  1. Canon Powershot Pro1 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Battery Replacement: passo 2, imagem 1 %32
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Battery Replacement: passo 3, imagem 1 %32
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Battery Replacement: passo 4, imagem 1 %32
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 967
