Ir para o conteúdo principal
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: passo 1, imagem 1 %32 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: passo 1, imagem 2 %32 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: passo 1, imagem 3 %32
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: passo 2, imagem 1 %32 Canon Powershot ELPH 100 HS Memory Card Replacement: passo 2, imagem 2 %32
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: passo 3, imagem 1 %32 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: passo 3, imagem 2 %32 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: passo 3, imagem 3 %32
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
Conclusão
Lillia
Membro desde: 03/17/15
255 Reputação
Autoria de 2 guias
Equipe
Michigan Tech, Team 1-10, Lauer Spring 2015 Membro de Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
Membros da 2
Autoria de 5 guias
Um comentário
my internal card reader hardware is not functional
can i replace it somehow
s l - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 33
Duração total: 1,028
