Ir para o conteúdo principal
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: passo 1, imagem 1 %32 Canon Powershot ELPH 100 HS Battery Replacement, Battery: passo 1, imagem 2 %32 Canon Powershot ELPH 100 HS Battery Replacement, Battery: passo 1, imagem 3 %32
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: passo 2, imagem 1 %32 Canon Powershot ELPH 100 HS Battery Replacement: passo 2, imagem 2 %32
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Conclusão
Uma outra pessoa concluiu este guia.
Lillia
Membro desde: 03/17/15
255 Reputação
Autoria de 2 guias
Equipe
Michigan Tech, Team 1-10, Lauer Spring 2015 Membro de Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
Membros da 2
Autoria de 5 guias
2 comentários
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - Responder
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 57
Duração total: 1,788
