Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will walk you through removing a faulty or damaged viewfinder.
O que você precisa
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
Three screws hold the viewfinder in place. Two on the top and one on the lens side of the camera.
First, remove the screw in the bent corner of the viewfinder.
