Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will help Canon Powershot A70 owners replace the speakers, if the camera is not giving off sound.
O que você precisa
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
Remove the two clearly visible screws from the control dial.
The dial should come off easily.
Uma outra pessoa concluiu este guia.
