Ir para o conteúdo principal
Canon Powershot A70 Shutter/Speaker Panel Replacement
O que você precisa
  1. Canon Powershot A70 Shutter/Speaker Panel Replacement, Shutter/Speaker Panel: passo 1, imagem 1 %32
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Shutter/Speaker Panel Replacement: passo 2, imagem 1 %32 Canon Powershot A70 Shutter/Speaker Panel Replacement: passo 2, imagem 2 %32
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
Conclusão
Shalan Ertis
Membro desde: 01/26/10
68 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-40, Regan Winter 2010 Membro de Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
Membros da 5
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 3,230
