Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This repair guide will explain, step-by-step the process necessary to replace the LCD Screen.
O que você precisa
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
Remove the two clearly visible screws from the control dial with a Phillips #00 screwdriver.
Remove the dial—it should come off easily.
Using a Phillips #00 screwdriver, remove the one visible screw that attaches the flex assembly to the back of the camera.
