Introdução
This guide will walk through the process of removing the button flex assembly from the camera.
Ferramentas
Peças
Não são necessárias peças.
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment.
Unscrew the three small screws on the bottom.
remove the wrist strap
Remove the two screws at the top of the battery compartment.
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
Three screws hold the viewfinder in place. Two on the top and one on the lens side of the camera.
First, remove the screw in the bent corner of the viewfinder.
Remove the two clearly visible screws from the control dial
The dial should come off easily
Remove the one visible screw that is attaching the flex assembly to the back of the camera.
