Ir para o conteúdo principal
Canon Powershot A610 Flash Unit Replacement
O que você precisa
  1. Canon Powershot A610 Flash Unit Replacement, Batteries: passo 1, imagem 1 %32 Canon Powershot A610 Flash Unit Replacement, Batteries: passo 1, imagem 2 %32
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Flash Unit Replacement: passo 2, imagem 1 %32
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Flash Unit Replacement, Camera Housing: passo 3, imagem 1 %32 Canon Powershot A610 Flash Unit Replacement, Camera Housing: passo 3, imagem 2 %32 Canon Powershot A610 Flash Unit Replacement, Camera Housing: passo 3, imagem 3 %32
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Flash Unit Replacement: passo 4, imagem 1 %32
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Flash Unit Replacement: passo 5, imagem 1 %32
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Flash Unit Replacement: passo 6, imagem 1 %32 Canon Powershot A610 Flash Unit Replacement: passo 6, imagem 2 %32
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Flash Unit Replacement: passo 7, imagem 1 %32
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Flash Unit Replacement: passo 8, imagem 1 %32 Canon Powershot A610 Flash Unit Replacement: passo 8, imagem 2 %32
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Flash Unit Replacement: passo 9, imagem 1 %32 Canon Powershot A610 Flash Unit Replacement: passo 9, imagem 2 %32
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Flash Unit Replacement: passo 10, imagem 1 %32 Canon Powershot A610 Flash Unit Replacement: passo 10, imagem 2 %32 Canon Powershot A610 Flash Unit Replacement: passo 10, imagem 3 %32
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
  11. Canon Powershot A610 Flash Unit Replacement, Flash Unit: passo 11, imagem 1 %32
    • Remove the 3 mm screw that holds the flash unit to the camera.
  12. Canon Powershot A610 Flash Unit Replacement: passo 12, imagem 1 %32
    • Using your forefinger and thumb, pull the flash unit upward, and out of the camera.
    • The flash unit capacitor may cause electric shocks. Do not touch both metallic ends of the capacitor simultaneously.
  13. Canon Powershot A610 Flash Unit Replacement: passo 13, imagem 1 %32
    • Remove the 3 mm screw that sits on the back of the circuit board.
  14. Canon Powershot A610 Flash Unit Replacement: passo 14, imagem 1 %32
    • Unsolder the white, yellow, brown, and green wires at their soldering points.
    • Remove and replace the flash assembly.
Conclusão
Matthew Ramirez
Membro desde: 01/20/11
625 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 11-26, Maness Winter 2011 Membro de Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
Membros da 3
Autoria de 9 guias
Um comentário
Where is loccated the CMOS Battery?
Belkis Orozco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 23
Últimos 30 dias: 39
Duração total: 5,456
