Introdução
This guide demonstrates how to replace the housing of a Canon Powershot A610. In order to get to the internals of the Canon A610, the plastic casing around the camera must be removed.
O que você precisa
Remove the three 3 mm screws that attach the side panel to the body of the camera.
Using your fingernails, pull the side panel outward to remove it.
Remove the two remaining 2 mm screws that attach to the frame of the camera.
3 outras pessoas executaram este guia.
