Ir para o conteúdo principal
Canon Powershot A3300 IS Motherboard Replacement
O que você precisa
  1. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: passo 1, imagem 2 %32 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Motherboard Replacement: passo 2, imagem 1 %32 Canon Powershot A3300 IS Motherboard Replacement: passo 2, imagem 2 %32
    • Pull off the back cover.
  3. Canon Powershot A3300 IS Motherboard Replacement, Front Cover: passo 3, imagem 1 %32 Canon Powershot A3300 IS Motherboard Replacement, Front Cover: passo 3, imagem 2 %32
    • Pull the front cover off.
  4. Canon Powershot A3300 IS Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Canon Powershot A3300 IS Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Remove the black cover to expose the motherboard.
  5. Canon Powershot A3300 IS Motherboard Replacement: passo 5, imagem 1 %32 Canon Powershot A3300 IS Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the shutter button located at the top left of the camera.
    • This will expose the screws that need to be removed.
  6. Canon Powershot A3300 IS Motherboard Replacement: passo 6, imagem 1 %32
    • Using a JIS 000 screwdriver, remove the 1.2mm screw at the top left of the motherboard.
  7. Canon Powershot A3300 IS Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the 1.6mm screw at the top of the camera.
  8. Canon Powershot A3300 IS Motherboard Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to pull out brown flat flexible wires from their connection.
    • Remember to gently wiggle the wires from the connection since they are very fragile connectors.
  9. Canon Powershot A3300 IS Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the last 1.2mm screw to pull out the motherboard.
    • The motherboard should freely separate from the housing.
  10. Canon Powershot A3300 IS Motherboard Replacement: passo 10, imagem 1 %32 Canon Powershot A3300 IS Motherboard Replacement: passo 10, imagem 2 %32 Canon Powershot A3300 IS Motherboard Replacement: passo 10, imagem 3 %32
    • Remove motherboard and replace with a new one.
Conclusão
Phillip Chen
Membro desde: 10/17/17
440 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 33
Duração total: 469
