Introdução
This guide will show you how to replace the front cover of your camera if it is broken or worn.
O que você precisa
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
Uma outra pessoa concluiu este guia.
