Introdução
If you have broken the back cover to your camera or it is worn out this guide will show you how to replace it.
O que você precisa
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
