Introdução
If you can not see an image through the eyepiece of your Canon PowerShot SX60 HS then use this guide to replace the viewfinder.
The viewfinder allows the camera user to see an image of what the camera is pointed at through the eyepiece located on the back of the camera. If you have any doubts if it is necessary to replace the viewfinder then please review our troubleshooting page before continuing.
Before starting this guide ensure that your device is completely powered off.
O que você precisa
Make sure to power off the device before completing any more steps.
Remove the battery by releasing the orange clip in the battery compartment.
Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
Use the iFixit opening tool to pry off the back panel.
Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
Once the ribbon is unplugged, remove the back panel from the camera body.
Use the Phillips #00 screwdriver to remove the two 2mm #00 silver screws located under the viewfinder.
Remove the plastic housing around the viewfinder by using a black spudger or opening tool to unclip the 3 plastic clips on the sides of the viewfinder.
