Ir para o conteúdo principal
Canon PowerShot SX520 HS Metal Plate Replacement
O que você precisa
  1. Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: passo 1, imagem 1 %32 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: passo 1, imagem 2 %32 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: passo 1, imagem 3 %32
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  2. Canon PowerShot SX520 HS Metal Plate Replacement: passo 2, imagem 1 %32
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  3. Canon PowerShot SX520 HS Metal Plate Replacement: passo 3, imagem 1 %32 Canon PowerShot SX520 HS Metal Plate Replacement: passo 3, imagem 2 %32
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Metal Plate Replacement: passo 4, imagem 1 %32
    • Once all screws are removed, pull the back facing off with your fingers.
  5. Canon PowerShot SX520 HS Metal Plate Replacement, LCD Screen: passo 5, imagem 1 %32
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Metal Plate Replacement: passo 6, imagem 1 %32
    • Carefully pop out the LCD screen with your fingers.
  7. Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: passo 7, imagem 1 %32 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: passo 7, imagem 2 %32 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: passo 7, imagem 3 %32
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
Conclusão
Lisa Choe
Membro desde: 09/22/15
460 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 4-4, Williams Fall 2015 Membro de Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 12
Duração total: 245
