Introdução
Did you drop your camera and crack the cover? This guide will give you step-by-step instructions on how to remove and replace the back face.
O que você precisa
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Uma outra pessoa concluiu este guia.
