Ir para o conteúdo principal
Canon PowerShot SX50 HS Rear Case Replacement
O que você precisa
  1. Canon PowerShot SX50 HS Rear Case Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Rear Case Replacement: passo 2, imagem 1 %32
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: passo 3, imagem 1 %32 Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: passo 3, imagem 2 %32
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  4. Canon PowerShot SX50 HS Rear Case Replacement: passo 4, imagem 1 %32 Canon PowerShot SX50 HS Rear Case Replacement: passo 4, imagem 2 %32
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  5. Canon PowerShot SX50 HS Rear Case Replacement: passo 5, imagem 1 %32
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  6. Canon PowerShot SX50 HS Rear Case Replacement: passo 6, imagem 1 %32 Canon PowerShot SX50 HS Rear Case Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  7. Canon PowerShot SX50 HS Rear Case Replacement: passo 7, imagem 1 %32 Canon PowerShot SX50 HS Rear Case Replacement: passo 7, imagem 2 %32 Canon PowerShot SX50 HS Rear Case Replacement: passo 7, imagem 3 %32
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  8. Canon PowerShot SX50 HS Rear Case Replacement: passo 8, imagem 1 %32 Canon PowerShot SX50 HS Rear Case Replacement: passo 8, imagem 2 %32 Canon PowerShot SX50 HS Rear Case Replacement: passo 8, imagem 3 %32
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
  9. Canon PowerShot SX50 HS Rear Case Replacement: passo 9, imagem 1 %32
    • Now you can completely separate the back encasement from the rest of the camera.
Conclusão
3 outras pessoas executaram este guia.
Daniel Gurrola
Membro desde: 04/01/15
267 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-7, Lancaster Spring 2015 Membro de Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 1,074
