Introdução
Replace the LCD screen of the Canon PowerShot SX50 HS.
O que você precisa
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Ferramenta utilizada neste passo:Tweezers$4.99
Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
Open the LCD screen panel.
Remove the two Phillips #000 screws, length 3 mm, on the outside edge of the LCD panel.
To detach the larger wire ribbon, lift the release latch on the connector of the circuit board. Remove the wire ribbon with tweezers.
Now remove the smaller wire ribbon by pulling on it firmly but gently.
the smaller ribbon can be removed/repositioned easily. There is a small hole that can be used to pull/push the ribbon
Use the curved tip tweezers to carefully remove the green circuit board out from under the two clips holding it in place. Then you can remove it completely with your fingers.
Now you can separate the LCD screen panel from the rest of the camera.
in the circuitboard are two tiny holes through which two pins keep it in position. You have to lift/tilt the board to remove it. Be carefull when reposition the board.
Use your fingers to remove the LCD screen from its encasing. It comes out very easily.
7 outras pessoas executaram este guia.
4Comentários do guia
hi, good afternoon…i’m from Peru..was wondering if you could help how to find screw to replace on my canon sx50…some of them, on the lcd, are starting to get rusty…i have no founf in ebay phillips 000 mscrew…just m2*3..or m3…which screws use the canon? thanks a lot in advance!!
Can use Canon Powershot SX60 HS LCD Display to Canon Powershot SX50 HS?
I am unable to get SX50 LCD Display to let me know if can I use SX60 Display?
