Introdução
Replace the eyepiece of the Canon PowerShot SX50 HS.
O que você precisa
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Ferramenta utilizada neste passo:Tweezers$4.99
Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
Remove the two #000 Phillips screws, length 2 mm, on the metal panel attaching the eyepiece to the rest of the camera.
Remove the two #000 Phillips screws, length 3 mm, attaching the metal panel to the eyepiece.
Using the curved tip tweezers unhook the clasps on the sides of the eyepiece that are holding its back panel in place.
Using the curved tip tweezers unhook the clasp on the bottom of the eyepiece that is holding its back panel in place.
4 outras pessoas executaram este guia.
