Ir para o conteúdo principal
Canon PowerShot SX280 HS LCD Screen Replacement
O que você precisa
  1. Canon PowerShot SX280 HS LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Turn off the camera and remove the battery.
  2. Canon PowerShot SX280 HS LCD Screen Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm screws on the left side of the camera.
  3. Canon PowerShot SX280 HS LCD Screen Replacement: passo 3, imagem 1 %32
    • Using the same screwdriver, remove the two 3.4 mm screws on the bottom of the camera.
  4. Canon PowerShot SX280 HS LCD Screen Replacement: passo 4, imagem 1 %32
    • Lift the small plastic tab, located on the front of the camera, to remove the GPS cover.
  5. Canon PowerShot SX280 HS LCD Screen Replacement: passo 5, imagem 1 %32
    • Using the same Phillips screwdriver, remove the two screws that hold the LCD screen.
    • Remove the other small tab attached to the LCD screen.
  6. Canon PowerShot SX280 HS LCD Screen Replacement: passo 6, imagem 1 %32
    • When removing the plastic casting, do not pull it all the way off. Detach the small tab first and make sure nothing else is attached to the casing.
  7. Canon PowerShot SX280 HS LCD Screen Replacement: passo 7, imagem 1 %32
    • To remove the tabs from the camera, remove all screws.
    • Slowly lift the screen out of the camera using the tabs.
  8. Canon PowerShot SX280 HS LCD Screen Replacement: passo 8, imagem 1 %32
    • Use the tabs, outlined in red, to slowly remove the LCD screen.
    • Remove the screws to remove the camera motherboard.
  9. Canon PowerShot SX280 HS LCD Screen Replacement: passo 9, imagem 1 %32
    • Insert the replacement LCD screen.
    • Ensure that the long strip is attached to the original position.
  10. Canon PowerShot SX280 HS LCD Screen Replacement: passo 10, imagem 1 %32
    • To reassemble your device, follow Steps 2 to 9 in reverse order.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Osmand A Munoz
Membro desde: 03/23/15
228 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-5, Miles Spring 2015 Membro de UMass Dartmouth, Team 1-5, Miles Spring 2015
UMASSD-MILES-S15S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 2,226
