Ir para o conteúdo principal
Canon PowerShot SX260 HS LCD Screen Replacement
O que você precisa
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: passo 2, imagem 1 %32
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: passo 3, imagem 1 %32
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: passo 5, imagem 1 %32
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: passo 6, imagem 1 %32
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: passo 7, imagem 1 %32
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: passo 9, imagem 1 %32
    • Gently slide the LCD screen to the right and remove.
Conclusão
3 outras pessoas executaram este guia.
Tyler Kelch
Membro desde: 03/05/15
622 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 33
Duração total: 3,763
