Ir para o conteúdo principal
Canon PowerShot SX260 HS Battery Replacement
O que você precisa
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: passo 1, imagem 1 %32
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: passo 2, imagem 1 %32 Canon PowerShot SX260 HS Battery Replacement: passo 2, imagem 2 %32
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: passo 3, imagem 1 %32
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Conclusão
Tyler Kelch
Membro desde: 03/05/15
622 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 25
Duração total: 1,076
