Ir para o conteúdo principal
Canon PowerShot SX160 IS Outer Case Replacement
O que você precisa
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: passo 1, imagem 1 %32 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: passo 1, imagem 2 %32 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: passo 1, imagem 3 %32
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: passo 2, imagem 1 %32 Canon PowerShot SX160 IS Outer Case Replacement: passo 2, imagem 2 %32
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: passo 3, imagem 1 %32 Canon PowerShot SX160 IS Outer Case Replacement: passo 3, imagem 2 %32
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
Conclusão
Jamie Secretan
Membro desde: 03/11/15
1.962 Reputação
Autoria de 6 guias
Equipe
Um comentário
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 1,837
