Introdução
This guide walks you through how to replace a broken LCD screen on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
O que você precisa
Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
Congratulations, you have successfully replaced your LCD screen. To reassemble your device, follow these instructions in reverse order.
