Ir para o conteúdo principal
Canon PowerShot SX160 IS Clock Battery Replacement
O que você precisa
  1. Canon PowerShot SX160 IS Clock Battery Replacement, Clock Battery: passo 1, imagem 1 %32
    • Locate the internal battery tray on the side of your camera.
    Thank you so much for your help. I was able to fix it without any problems.
    Barbara - Responder
    Your instructions to replace the battery was most helpful. Thank you.
    Barbara - Responder
  2. Canon PowerShot SX160 IS Clock Battery Replacement: passo 2, imagem 1 %32
    • Use your finger or a spudger to gently pry the battery tray out of the camera.
  3. Canon PowerShot SX160 IS Clock Battery Replacement: passo 3, imagem 1 %32
    • Fully remove the battery tray from the camera.
  4. Canon PowerShot SX160 IS Clock Battery Replacement: passo 4, imagem 1 %32
    • Remove battery from tray and replace.
    These photos show the battery upside-down. The positive goes down, towards the plastic tray, while the negative goes up, towards the open top of the tray.
    tomcatanzaro - Responder
    Thanks, Tom! I first put the battery in the way the photo displayed, and then set the date. When I turned the camera off, then on again, I got the message the date and time needed to be set. Changing to your way solved my problem! Thanks so much!!
    William Burke -
    Where can I buy batteries like these? Thanks
    Nicole - Responder
    Need a new battery tray…. Is there a way to get this part.
    Judy Bogner - Responder
Conclusão
Congratulations, you have successfully replaced the internal battery. To reassemble your device, follow these instructions in reverse order.
37 outras pessoas executaram este guia.
Jamie Secretan
Membro desde: 03/11/15
1.990 Reputação
Autoria de 6 guias
Equipe
17 comentários
Clear and simple. Thanks!
Jim - Responder
I had no idea! Thanks!
natorbett - Responder
Its not necessary to unscrew the tray.
Afzal Pawaskar - Responder
Thank you, Jamie!
Casey Cain - Responder
Gee I thought I am so glad I checked the Internet first...(before I threw it in the trash) that is how frustrating this was. Thank you everyone, I do love this camera
Barbara Rivers - Responder
thank you, i couldn't find it in the manual
ramar - Responder
Best camera I've ever had yet. All I have to do now is find a supplier for the battery.
carverdoone - Responder
My sentiments exactly like Barb Rivers. It's great to have someone like you guys do such a pro. job.
Many thanks and keep up the good work.
Richard Lange - Responder
Where do I go to buy this battery?
Louise Gladkowski - Responder
Love the canon camera I have this one, but it drains batteries when taking pictures? I have to bring a 8 pack of batteries it’s crazy!
Bonnie Bennett - Responder
I have a canon camera love it but it drains batteries have to bring a 8 pack something not right? Please let me know if it’s fixable or get a different one? Thanks
Tried for 2 days to get in touch with Canon with no response, Jaime solved it in seconds !
Drew - Responder
The pictures are wrong, the (+) and (-) are switched. Read the battery holder, that’s ok. Eze
adreze - Responder
i put new batterry to take shot still it showing low battery what will be the problem
montu bhagat - Responder
hi. direction easy, but still have problem
Suzanne LaCroix - Responder
got the battery out ok. now where the !&&* do i get a new one? no one carries it around my neck of the woods….
suesan629 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 51
Últimos 30 dias: 195
Ao todo: 50,542
