Ir para o conteúdo principal
Canon PowerShot SX120 IS Back Cover Replacement
O que você precisa
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: passo 2, imagem 1 %32
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: passo 3, imagem 1 %32 Canon PowerShot SX120 IS Back Cover Replacement: passo 3, imagem 2 %32
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: passo 4, imagem 1 %32 Canon PowerShot SX120 IS Back Cover Replacement: passo 4, imagem 2 %32
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: passo 5, imagem 1 %32
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: passo 6, imagem 1 %32 Canon PowerShot SX120 IS Back Cover Replacement: passo 6, imagem 2 %32 Canon PowerShot SX120 IS Back Cover Replacement: passo 6, imagem 3 %32
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: passo 7, imagem 1 %32
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
Conclusão
Maria
Membro desde: 03/13/14
875 Reputação
Autoria de 1 guia
Equipe
Um comentário
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,719
