Ir para o conteúdo principal
Canon PowerShot SD960 IS Battery Replacement
  1. Canon PowerShot SD960 IS Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the camera over so that the bottom of the camera is facing up.
  2. Canon PowerShot SD960 IS Battery Replacement: passo 2, imagem 1 %32 Canon PowerShot SD960 IS Battery Replacement: passo 2, imagem 2 %32
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
  3. Canon PowerShot SD960 IS Battery Replacement: passo 3, imagem 1 %32
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 489
