Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this repair guide to remove the faulty release button from your Canon PowerShot SD870 IS.
O que você precisa
The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
The LCD screen should now only be attached by the LCD data cable.
Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
Carefully slide the data cable out of the connector.
The LCD should still be connected by the backlight cable.
The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
Carefully disengage the claws by gently prying them off one by one.
Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
Carefully peel the backlight cable off of the casing.
With the case and LCD screen removed, you are ready to remove the release button.
Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
Uma outra pessoa concluiu este guia.
