Introdução
Use this repair guide to replace a broken LCD screen on your Canon PowerShot SD850 IS.
O que você precisa
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
Uma outra pessoa concluiu este guia.
