Introdução
This manual is for replacing the function/set button located on the back of the camera.
O que você precisa
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
