Ir para o conteúdo principal
Canon PowerShot SD850 IS Battery Replacement
  1. Canon PowerShot SD850 IS Battery Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot SD850 IS Battery Replacement, Battery: passo 1, imagem 2 %32 Canon PowerShot SD850 IS Battery Replacement, Battery: passo 1, imagem 3 %32
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Battery Replacement: passo 2, imagem 1 %32 Canon PowerShot SD850 IS Battery Replacement: passo 2, imagem 2 %32
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
Conclusão
To reassemble your device, follow thee instructions in reverse order.
Peter Tran
Membro desde: 10/06/10
225 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-7, Maness Fall 2010 Membro de Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
Membros da 6
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 3,024
