Ir para o conteúdo principal
Introdução
Remove the back cover before removing LCD.
Peças
Nenhum componente especificado.
  1. Remove one 2.25mm screw on the bottom.
    • Remove one 2.25mm screw on the bottom.
  2. Remove two 2.25mm screws on the right side looking from the front.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Remove one 4.7mm screw on the side with the AV output.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Pull off the back cover.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Remove 2 2.4mm screws on bottom.
    • Remove 2 2.4mm screws on bottom.
  6. Follow the small data cable to where it connects to the camera.
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Gently lift LCD display off.
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Follow the larger cable to where it connects to the camera.
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
Conclusão
2 outras pessoas concluíram este guia.
Jeremy Rabaino
Membro desde: 10/10/2010
135 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 20-9, Maness Fall 2010 Membro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Membros
6 Guias de autoria
Um comentário
where can I buy a replacement LCD screen for a SD800 IS
ALFRED - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,173
