Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Canon PowerShot SD800 IS LCD Assembly Replacement
O que você precisa
  1. Canon PowerShot SD800 IS LCD Assembly Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove one 2.25mm screw on the bottom.
  2. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 2, imagem 1 %32
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 3, imagem 1 %32
    • Remove one 4.7mm screw on the side with the AV output.
  4. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 4, imagem 1 %32
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Canon PowerShot SD800 IS LCD Assembly Replacement, LCD Assembly: passo 5, imagem 1 %32
    • Remove 2 2.4mm screws on bottom.
  6. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 6, imagem 1 %32
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 7, imagem 1 %32
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 8, imagem 1 %32
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
Conclusão
Jeremy Rabaino
Membro desde: 10/10/10
135 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-9, Maness Fall 2010 Membro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
Membros da 5
Autoria de 6 guias
Um comentário
where can I buy a replacement LCD screen for a SD800 IS
ALFRED - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 2,291
