Introdução
This guide will help you remove and replace the outside case of the Canon PowerShot SD700. Follow the step-by-step instructions to remove the outside case of your Canon PowerShot SD700. You will need Phillips #00 screwdriver to complete the steps throughout the guide.
O que você precisa
To reassemble your device, follow steps 1-6 instructions in reverse order.
3 outras pessoas executaram este guia.
