Ir para o conteúdo principal
Canon PowerShot SD700 Backlight Replacement
O que você precisa
  1. Canon PowerShot SD700 Backlight Replacement, Outside Case: passo 1, imagem 1 %32
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Backlight Replacement: passo 2, imagem 1 %32
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Backlight Replacement: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Backlight Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Backlight Replacement: passo 5, imagem 1 %32
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Backlight Replacement: passo 6, imagem 1 %32
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 Backlight Replacement, LCD screen: passo 7, imagem 1 %32
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 Backlight Replacement: passo 8, imagem 1 %32 Canon PowerShot SD700 Backlight Replacement: passo 8, imagem 2 %32 Canon PowerShot SD700 Backlight Replacement: passo 8, imagem 3 %32
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 Backlight Replacement: passo 9, imagem 1 %32
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
  10. Canon PowerShot SD700 Backlight Replacement, Backlight: passo 10, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unplug the ribbon from the housing on the circuitry.
    • Take the new ribbon and insert it into the housing.
    • Tweezers or a tool with a sharp point can be used.
Conclusão
Emilio Rossi
Membro desde: 04/07/11
113 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-71, Walters Spring 2011 Membro de Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,629
